OK, just cut the back of the cam. I'm still having a hard time picturing how the torrington will sit in there, If I put it (bearing) on the cam it seems like it has too much slop around it? Will the cam button keep it centered once torqued down?
In pic 1 I have the bearing sitting on the cam, it seems once it is slid into the block the bearing will move around.
Pic 2. Which part needs to be turned down, A? Or the very front of the cam where the button goes into?
 Brainstorm, I guess you would have to machine "A" so the front cam journal can go into the block properly. Should I basically machine the thickness of the bearing off the cam?
Pic 3. Shows how much "slop" there is in between the cam and bearing.
Pic 4. This is what the bearing looks like compared to the block.
Pic 5. This is the repair they made to the block, I think I'm going to take it back and have the machine the front a little so I know it square, but I can't go too much or the cover wont line up with the girdle.
I need a drink, and a Joint!
Summit. $11.99 CCA-3110TB
