new ckperformance 4r70w/aode transmission
chris718
we currently are making the electronic version of the aod for the buick ,chevy olds pontiac and ford crowd.valve body is a reverse pattern with transmission brake like the aod but now features the addition of a lock up clutch style converter.initial test are showing big performance gains over the aod in the shift department as well as the improved performance of the geroter type a;uminum front pump.there are no electronics necessary for operation of the transmission and as usual you can use your original speedo cable,shifter cable ,trans lines etc.as we progress we will add other features such as auto shift with transmission brake.the lock up converter in itself is a tremendous improvement overthe aod.small issues to be worked out but were moving ahead at breakneck speed.
