new engine car wont start
Will need more info....
What have you tried.... or ruled out?
Based on the lack of info...... I'll guess cam sensor?
Is this the car in your sig, or your dd Yugo?? At any rate, Pep Boys can fix it!:D
Based off the description it sounds like a combination of a broken crank, bent rod, and low blinker fluid... Or maybe a Mis adjusted cam sensor or a cam/crank sensor not plugged in or the crank sensor in the wrong notch..
,Dan
