Purchased GN, 36K original miles, finally after 2 years on this board. I know all about modular mustangs but need some help with reading a scanmaster and tuning. I have 60mm turbo, 50 lbs inj., alkey injection, bored .41 over, mild ported stock heads, 62mm TB, 3" DP and exhaust with ext wastegate. Here are my readings at idle
O2 - 492 - 515
Af - 05
LV8 - 39-40
INT - 128
BLM - 150
ATS - 102
RPM - 725 - 775
TPS - .44
IAC - 55
CC - 113
MAL - 13
Any other information I need to give? Malfunction code is slow responding 02 sensor, where is this sensor? Idle seems a bit rough. Cam has 10/10 grind. How do I get the maximum performance out of this car. thanks for your help.
O2 - 492 - 515
Af - 05
LV8 - 39-40
INT - 128
BLM - 150
ATS - 102
RPM - 725 - 775
TPS - .44
IAC - 55
CC - 113
MAL - 13
