New Grand National Owner
You look like you already have a car that is capable of 12's. Just because you think it feels slower than your LS1, don't mean that it is. Nice looking GN. I would suggest sitting down and reading and asking questions on these TR boards.
Very nice and clean
That old ATR air Filter inlet was almost as restrictive as the orignal airfilter canister. Had one they don't work. A new MAF pipe would flow smoother then the convoluted MAF hose. Mark Hueffman (TR Custom Parts)has some very nice options that will help her breath inhale better. Nice DP as that's definately a worth while upgrade. These cars love to breath another area you may look at is if you have a gutted cat. The cat is probably the most restrictive piece of equipment. Nice score!
What are you guys seeing on the vacuum brakes? Thanks, Clint
Clint,
they came with a powermaster brake setup, electric motor type deal that worked great...when it worked
pull the ecm out from pass side kick panel, undo the cover and post the writings on the chip
clean looking under the hood
I agree. I have rode in a few mustangs that sounded and felt REAL fast but didnt produce good numbers at the track. These cars are quiet and have such a smooth power curve that they feel slow but actually they are not.
These cars are way Kool man . That's great that you picked up a very nice low mileage one. She's a beaut... For sure get a ScanMaster 1st . A larger SLIC would be a very nice upgrade down the road, you may consider Alky and Turbo Tweak chip before the IC. So that you only spend a half a ton of money you might buy used. Lot of guys upgrade to larger turbos , injectors, FMIC. so alot of times you can get some low mileage equipment at a reasonable cost. Picked up a a good clean TE-44 turbo for $250, also a Translator and 3.5" MAF for $150. Some very goodguys on here and are very knowledgable and most of all willing to help out. Have fun and welcome aboard.
x2 Ifyou wanna go fast. I find boost adictive!!!
What your boost set at ?? put some good gas in it and turn up the boost 5 # and get back to me...
Welcome to the dark side, nice looking car. My suggestion is: before you even think about turning any wrenches you need to read, read, read. Almost anything you can think to ask has probably already been answered at least a half a dozen times so learn to use the search function. But if you can't find it, us guys love to talk so we'll answer it again and again. :D
As far as 12's. Some good tuning, good gas, more boost, traction, and a good launch and you should be pretty close with out having to spend a fortune. No stretch cooler needed. If you do want a little more a Duttweiler necked stock cooler can be a bargain and have been deep into the 11's. You will need some type of scan tool and with lots of patience you will find out it's not as hard as you think.
Also, check your driver side header for any cracks between the arms, the previous owner probably had it welded already..Any exhaust leaks before the turbo will kill your spool-up time..
remove your turbo sheild, cut around about an inch and half or so from the top and reinstall...it looks like they gorilla'd it on there over the DP
It has a stock delco chip in it, but in the box of stuff that came with there was a hypertech chip. I installed it and I did notice a difference.
pull off the turbo sheild, while your trimming it, snap some pics of the turbo, prolly stock as is injectors, you'll want to get 60# injectors with matching chip
prepare your self...your gonna get hooked and hooked hard
:biggrin: I Was Able To Run Mid 13's With Just Hooker 2 1/2 Exhaust,test Pipe And 235/15/60 Drag Radials.after Adding The Additional Mods List Down On My Signature, My Gn I Believe Should Be In The High 12's
To Low 13's With 17 Psi. I Out Ran A Low Mile Corvette C5 By 2 Cars And A 2007 Dogde Charger Srt-8 Which Both Are Low 13 Second Cars.
STICKY TIRES $1000 DOLLARS SHOULD GET YOU NEAR THE 12'S THAT PRETTY MUCH WHAT I HAS SPENT BEFORE MY TURBO WENT SOUTH ON ME
WELCOME HOME WE HAVE BEEN WAITING FOR
that chip is useless get a turbo tweak chip:wink: and call it the day
looks like a clean car.but like what randy said read,read and read.
When you first start reading and tring to learn about these cars its like tring to learn a new language. Just read as much as you can, and ask questions about what you don't understand.
