they told me every other bearing in the motor was fine. The guy there told me the solution would be a deep sump pan for more oil but if that were the case dont you think it would have starved more than one bearing and also he had the nerve to ask me if i put enuff oil in the motor. I had one quart in the filter filled the turbosavers lines with oil and had almost 5 and a half in the pan when i primed the motor. The other thing that made me mad was they wanted to inspect it when i was there and before i brought it to them they told me not to take anything apart including the heads even though they just did the shortblock. They were the ones that installed the timing cover also and did the port work to it. Also the guy said that my bearings looked like i detonated it but i never even hooked up the wastegate rod so that i wouldnt get any boost to it and the scanmaster never showed any either.
Inspecting it while you were there is a good idea,i would have absolutely wanted to be there when it came apart,so i could see exactly what happened.
A regular pan should be sufficient to have oiled it properly for the amount + type of driving you explained, hell a squirt of vegetable oil should have taken you 38 miles.
+ it keeps coming back to that 1 bearing ,if the motor was starving for oil why did just that 1 rod bearing take such a beating ,that it destroyed the crank,+ put so much metal in the filter + pan in such a short time,yet everything else is fine? why just that 1 rod bearing? Its too bad you didn't have another machinest look at it,+ too bad you were not there at the tear down,have you inspected it since it came apart ? If not i think it would be worth your while to check it out.
I've had alot of motors built over the yrs,+ a few bad ones,+ never did a machine shop just say ok i screwed up,i'll make it right,i had to push them to make it right,they made every excuse in the book + tried to blame everybody else,even when it was clearly + without a doubt, their fault,+ then it was a battle to get them to get it done,once they couldn't deny it anymore.(I'm not sayng that is what is happening here,that has just been my experience).
I had a shop build me a complete blower motor,he put a line that he was all proud of on the blower,so that if it built up too much pressure it would blow the excess oil into the oil pan to relieve the pressure,but nothing to replenish it with oil so about the third time i got on it,the blower had no more oil in it,+ munched itself,he blamed it on me,the gas,the oil manufacturer,the blower manufacturer,god,mother theresa,the weather,you name it,even with a blower with his blow off line + nothing to refeed it after it blew off the oil,staring him right in the face,he still would not take the blame,finally had to get a lawyer + threaten to go after triple damages + court costs then he finally,said he would fix it,but still wasn't admitting any wrong doing,i had to make him admit in writing,that his line emptied the blower of oil + killed the blower,+ that he would fix it completely,before i would cancel the lawsuit, it was the only thing that could have ran the blower dry,but he knew it was going to cost him time + money so he wouldn't admit it + make good on it, + that was the biggest most well known shop in the area,he even owned + raced his own dragster/funny car,it wasn't just a rinky dink shop.
Thats just one of a few different machine shop problems i've had of not making good,I just stopped having motors built,+ pretty much only buy running cars now with proven motors,I was just about to buy a complete ,newly built motor this week,but after reading about yours it brought back old memories + i decided against it, i was already thinking about the bad possibilities,because of the past + yours just reaffirmed it.
Good luck + i would push for them to make good unless they can come up with a good reason why the motor they just built couldn't make it to 40 miles. The oil pan excuse just isn't cuttin it. Did they test the oil pump? Was the top end being oiled ok?
I just reread the post + notice you said,That they said all the other bearings look fine but,in another spot you said, that they said the bearings look like you detonated it,what is wrong with the other bearings that made them look like there was detonation? I would go to the shop + inspect this whole thing yourself if you havn't already.good luck.
