its a good plate for stock crank or external bal forged which you could get on a stock stroke eagle , i run that plate on my 86 which has an early eagle external forged crank ,
on a forged crank you  need to chamfer the inside edge to clear the radius on the crank hub  , takes a couple seconds with a die grinder to v the back edge
you can tell its for external by the 3 large holes on one half of the plate and the other 3 arent cut out making it heavier on one side  , the pattern is a copy of the stock plate
the internal plate is neutral balanced and has the 6 large holes  all the way around the plate like the one that full throttle has a pic of (their pic is of a sb chevy plate but that is internal )  which makes the plate balanced so the crank has to be internal balanced
