New PT6466BB turbo, does the exhaust WG hole need porting?
Discussion in 'Turbos and turbo related parts' started by 2QUIK6, Jun 1, 2017.
  1. Pronto
    Pronto
    Expand Collapse
    I read the books and followed the instructions.
    Dec 9, 2002
    11,002
    654
    Online
  2. 2QUIK6
    2QUIK6
    Expand Collapse
    Turbo Milk Jug displacmnt
    May 28, 2001
    4,592
    54
    Offline
    I finally got it back together, with the 13# actuator with a very light pre-load it controls boost steady at a minimum 20psi which I have never had it lower than that in 15 years or more. Will probably add just a little more pre-load so it spools a tad better and call it done, boost Cmd is set at min, can turn it up and it does fine and steady up to 24#.
    WG hole is ported out to 1.15" and alot of material was removed on the inside front radius. The back, closest to the turbine was left square to act as a wall to slow down the air flow and direct it more to the WG hole.
  3. dank GN
    dank GN
    Expand Collapse
    always something
    Jan 11, 2009
    2,388
    183
    Online
    If you can't go lower then 20psi I would say you still have issues . You are most likely runing a ton of back pressure . I would look into ether a external wastegate setup in the stock location or something plumed off the header crossover . I have a 281 cid with a 7168 comp turbo with a .85 exsaust housing and even though my back pressure is pretty high I can still get my boost down below 10psi . If you are happy with a 20psi minimum then rock it but in my opinion I would look into getting it lower .
Share This Page
