SignUp Now!thank you.. please if you would, post letting us know that the configuration screen has been update so i can pre-order
We have ONE sample DP system available with optional 120 ohm level sender for the digital dash TR.
First come first serve.
Full stock on the DD senders will be APPROXIMATELY 45 days.
http://www.racetronix.biz/customkititems.asp?kc=DPFS-G7&eq=
Same time frame as DP / same sender.Any word on the digital dash unit with 1 pump?
Can you give us alittle more info on the teflon hose ie; will it be made up to do a full replacement of the fuel lines from tank to engine or in sections to add in a filter, fuel regulator etc.
I just installed mine a couple weeks ago. It is very nicely made, installation went smoothly. Everything works great. Now my fuel gauge works (didn't before).
One note, the kit needs to come with a picture/sheet that shows how to aim the fuel socks.
Also, what is the pressure switch preset to? I have not adjusted it yet, and am curious what its base setting is.
Bob
Thats the way we faced them, they hit the baffle a little so we weren't sure. Everything works great.
I was not the person that ordered the kit, I will check.
Thanks!!
Bob
We now have the Aeromotive 11140 340LPH pumps in stock. We have added these pumps as an option to our DPK-003 DIY DP Kits and our complete DPFS-G7 DP Systems.
680LPH of fuel...
Thanks!
