I recently installed RJC's deep oil pan. Now when I start it cold I get that slight rattling sound for a couple of seconds till pressure picks up. Is this due to the oil traveling further up the pickup extension? Either way, I don't like it.:frown:
SignUp Now!rattle sound? what kind of sound? never had a problem with my deep pan on startup.
try a different oil filter, or problem with pickup seal, maybe.
Lifters came with cam from TA perf. Not sure of brand. At least now I know my bearings are'nt starving for oil on startup.Not the pan per say, maybe lack of proper seal with the pickup (but I doubt that with a fresh gasket).
After new lifters (GM), mine rattles some but I live with it.
Then I fixed the problem.
Look into a pre-lube unit, it ended my rattles with pressure at 35 lbs starting.![]()
Weak oil pump trying to get the oil moving??
I was just doing some maintanance for longevity. Cam/lifters/double roller TC/new timing cover/pump/oil pan.
How ironic. I had to remove the new pan "today" because the crank was barely nicking the baffle. I just pushed the corner down a tad and presto. I'm glad these pans come off easily. But this had nothing to do with startup noise, though it is funny you posted about the baffle.I had the same problem when I installed the RJC pan. It might be one of two things: the spot welds came loose on the baffle or the crank is hitting the baffle. I had both problems with this pan.
Jeff
Jeff Rand said:I had the same problem when I installed the RJC pan. It might be one of two things: the spot welds came loose on the baffle or the crank is hitting the baffle. I had both problems with this pan.
Jeff
