New TH400 Polished Aluminum Trans Pan with Temp Bung Welded in
87TurboGN
This is a aluminum pan from Jegs that I had a Temp bung TIG welded in, never used. I have a gasket for it also, no mounting bolts. This is the stock size pan, not a deep pan. See the jegs part number, this pan was $60 new plus the Bung. I will take $50 plus shipping.
WHats the depth of the pan from the mounting rail to the bottom inside? Does it hold any extra fliuid at all over stock?
2.25 inches. Should be the same as stock. Aluminum allows the fluid to cool much quicker.
