newbie scan master question
powerwagon05
i just put a brand new scan master in my car,took a couple runs down the street and it seems to be ok. anyway when i try to recall the readings i dont get anything for kr or knock it starts on af and goes on from there, should i take that as a no knock detected or is there something wrong with my new sm ? thanks in advance.
David:confused:
PUshing the wrong button?? After the run you need to press the button on the right side.
when the tps voltage reaches 3.00v it then begins to record the run. it records the highest kr and lowest o2 readings. then press the button on the right side to recall.
Duhh I was wrong!!!
Now I wonder how high my 02s hit over all, the scanmasrter had an 855, 898, 875 at the end of a few runs.
