SignUp Now!I'm going to see if I can make it work with the frame as it is.Hope you like the idea I PM'd you Don. And yes the car need the preload for a beter launch. You might be better off seeing if you can straighten the frame first.
I read the PM. It's already back together now.I'll run it as is and see if I need to make that change or not later. Thanks for the tip. I never would have thought of that.
QA1 coil-over shock conversion for the front is on order.
The left front caliper is dragging pretty good. I might be looking into going with a new front braking system too.
I'm looking at the Strange Pro Race steel front kit for stock spindles. 4 piston calipers. Does anyone have any issues with them? How do the rotors hold up? No planned street use.
I think I'm going to start a thread on the weight balancing adventure. It will be in the suspension section when I get around to it. Next week, I'm sure.JUST REMEMBER TO GET THE WEIGHTS SET PLEASE! Hope you do good Donnie and keep me up to date.
Just started it. Check the Suspension section.I like it Donnie. PM me when you start the new thread for sure. Looking foward to it myself.
