SignUp Now!What down pipe? My old TE-44 which was ported for a THDP would not build any boost with the stock elbow as the WG hole was much larger than the puck.
i'm using my stock downpipe and elbow.. i do have a 3" from poston buick but i don't have an elbow to connect it...
Check the size of the WG hole in the exhaust housing and the size of the puck - there is a good chance the hole is larger than the puck - if so you will never build boost until the problem is fixed.
by puck are you refering to the dounut between the down pipe and the turbo?
