How much clearance should there be between the front face of the front cover and the trigger wheel?
The engine pictured is being assembled and has zero clearance, as can be seen by the scratch on the front cover. The engine is a 109 block, stock front cover, cometic front cover gasket, stock balancer and crank trigger wheel, front cover is torqued to spec, and so is the crank bolt. The crankshaft is out of a carbed 3.8 turbo, perhaps the nose on carbed cranks is shorter?
The clearance between the trigger wheel tips and bottom of the crank sensor is pretty much zero as well.
Has anyone out there shimmed under the balancer to correct this?
TIA
-john
TIA
-john
