t-typinator
- Oct 8, 2010
I was surprised a few months ago when someone said they still had stock radiators out there + any auto store had them + were cheap.
I went + checked auto zone + they had them for $100 + the turbo t/a rads were $110.
I checked yesterday + now they are over $500 at auto zone + advanced auto. found 1 for 450ish at cap.
I called a buick dealer + they are no longer available.
So i looked into a 89 TTA radiator + they are available,for less money so i guess thats the route i may go.
The t/a rad looks a bit different,and it looked like it had an extra fitting towards the top of the tank just above the upper oil cooler fitting hole.
My question's are : Is this radiator a direct bolt in or is there any mods needed to use this radiator?
Also what is the extra fitting,Overflow maybe ?,I should have checked a bit better, but i know it wasn't up on the filler neck where the little overflow tube is.
will the stock oil cooler lines from my t-type fit the t/a rad both in length + fitting size,i noticed the female fittings on the rad were plastic but i didn't check size.
