i swapped out my motor for a spare one i had for a project.
its got spark and fuel, everything is hooked up but does not catch on the start..in other words it plutters and shuts off.
this motor has the same injectors as the other so using same TT chip
tried unplugging the maf, changing out the iac but cars should start.
pump primes each time, fuel pressure is approx 40.
please help with some other suggestions.....motor has been sitting for 3 years and did hear it run before buying it.
i had also soaked the cylinders with wd40 and oil for a few days before putting the motor in. i've turned it over enough times that it shouldn't be soaking the plugs.
