I posted this resently, but didn't get any definite ways to go. I now have a lot more data. What's happening is my ECU isn't seeing the WB O2 all of a sudden. I've had problems with the indicated A/F "locking up" on some random number before. But here is some data I just got. My ECU serial number is 714.
Key on, car off, WB O2 connected
UEGOS 1.12-1.10
UEGO 3.53
UEGOR 2.49-2.51
Diag A 1275 one time, 1285 second time
Key on, car off, WB O2 NOT connected
UEGOS 0.80
UEGO 3.51
UEGOR 4.98
Diag A 2545
Key on, car running, WB O2 connected
Initally after starting :
UEGOS 0.47
UEGO 0.84
UEGOR 2.47
Diag A 1275
After running about 1 minute :
UEGOS 1.12-1.18
UEGO 3.53
UEGOR 2.49
Diag A 1295
Code 8
Key on, car running, WB O2 NOT connected
UEGOS 0.82
UEGO 3.53
UEGOR 4.98
Diag A 2545
The WB O2 sensor is ALWAYS 0, and I never see the lamda symbol on the bottom right corner. I also tried some older programs to see if I screwed up something in the program, but got the same results. The A/F indicated now is 0.00 90% of the time. Sometimes when I start the car it will lock into some other number, but it will never change once the car is started.
ANY ideas would be VERY much appreciated. I did just rebuild the motor so I was thinking maybe a broken wire somewhere, but it worked initially after the rebuild.
Thank You for ANY help.
Derrick
UEGOS 1.12-1.10
UEGO 3.53
UEGOR 2.49-2.51
UEGOS 0.80
UEGO 3.51
UEGOR 4.98
Diag A 2545
UEGOS 0.47
UEGO 0.84
UEGOR 2.47
Diag A 1275
UEGOS 1.12-1.18
UEGO 3.53
UEGOR 2.49
Diag A 1295
Code 8
UEGOS 0.82
UEGO 3.53
UEGOR 4.98
Diag A 2545
Derrick
