HellOnWheels
HellOnWheels
- Feb 3, 2002
87GN. Did a manual downshift to 2nd, hammered throttle, after which it will no longer do wot shifting. Will be in 3/4 by 40-45 mph.
TV cable has spring tension, new TCC, governor and springs in place, solonoid fuse okay, new fluid and filter, all wiring properly hooked up, TV cable yanked several times and properly adjusted. Other than no wot upahifts the trans works aokay. I dread having to drop the vb but looks like that's where I m at!! Any other suggestions before the dreaded vb drop will be much appreciated.
