Once again, we are just dealing with theories until you turn the boost up. Much like you exceding your 700hp goal, I think you are selling your combination short and predict you will make a lot more boost than 35 when you get the car ironed out. Heck, your already flowing enough air now to make (according to you) around 1200hp and turn 7800rpm.
Now, I'll ask the question :smile: Since your original design goal was 700 hp. Why did you chose that turbo? As much research as you do, I would have thought you would of come up with something else. Especially since you now think it is going to limit you from making as much hp as a "cookie cutter" turbo. Cost can't be the issue when you consider how much you have had to put in NOS. It can't be turbo efficency when considering your original goal. It wouldn't be the "bling" factor of having a huge turbo, you have the NOS purge for that :wink:
You guys keep coming up with questions that I've answered over and over again in other threads. I mean, I don't mind answering them, but I'd have thought you guys were sick and tired of me going over the same stuff over and over again. The 'Novel', as some of you have put it, that I authored covers everything about my project including why I've made the choices I did. Maybe some of you should reread that before I turn this thread into another novel.
To answer your question Cal,
the original hp target for the project was 700 hp. That was mainly due to my lack of experience with the relationship of head flow potentials to hp potentials. This engine was basically my first 'designed from the ground up' engine. Let alone a turbocharged one.
Back in those days when I was putting the engine configuration together, 66mm turbos were considered real big. Bigger turbos were reserved for the Stage II headed monsters.
When I received the flow numbers for the heads, 210 cfm on the intake side, I could not help but be modestly optimistic about the hp potential of the configuration. 210 was only slightly above what a stock head could deliver. I looked around me to see what other people were doing at the time and figured, OK, I should be able to get 700 bhp out of these heads and went with that. That thinking dictated my turbo choice. That was a T70.
I figured that if I broke into the high nines, I would be a happy camper. Although, I was more sure I would end up in the tens, somewhere.
The first time down the quarter with the car was at the 2005 WCNs. I think I had just put on the T76 because of a porcelain accident while learning the alcohol with the T70. I don't remember my train of thought that led me to upgrade to the T76. It may have been due to seeing a few others around me trying out the T76 or the sim was showing me that there was potential with it.
The engine sim that I used to basically come up with the original configuration and that has been tweaked along as the project has progressed has had a lot to do with my choices with the engine.
Anyway, at the 2005 WCNs the car did a low nine pass. I was shocked. It was beyond my wildest dreams. Imagine expecting a low ten pass maybe and then coming out of the gate with a low nine second pass. That's almost an 8 second pass!
Well, after that the sim went through a lot of tweaking. There were obviously a lot of inputs that weren't relating well to real world. Most of the tweaking involved the head flow numbers.
Once those were tweaked to a point where the sim better matched real world, it allowed me to play with different turbos and get a better picture of what turbo would be the most efficient for the engine. I was only slightly concerned with max hp. I realized the heads were going to be the limiting factor. I strictly looked for the most efficient turbo. The 91mm was it. The sim was crazy for it. For this head configuration, this turbo is smack dab in the middle of the eff island at 1200 bhp. 78% efficiency, with the data point rising right up through the middle of the efficiency islands as boost is increased.
Spooling was not a problem that I completely ignored. The sim also showed me that this turbo would be an absolute bear to spool. Yes, I was warned way ahead of time about this problem. Knowing that I would be using nitrous to spool the turbo, I wasn't too concerned.
Another interesting thing about the sim. When I was using the T76, that was when I really started to use the nitrous to spool. The sim told me I would need a 200 shot to spool the T76. I went straight to a 200 shot, and it worked perfectly.
When I was doing the sim work for the 91mm, before I even bought the 91mm, the sim was showing me that I would need a 400 shot to spool it. Of course, I didn't go straight to a 400 shot. I worked up on it, but look at where I'm at with it now. 364 shot port injected with a 50 shot into the turbine housing. Pretty amazing isn't it.
The sim also has shown that this engine combination will be lucky to spool this turbo to 35 psi. That is what I'm basing a lot of my assumptions on. Now with the sim more dialed in due to real world comparisons, it's become pretty accurate at predicting how the setup will work.
As far as the bling factor. Yes, people like to see the nitrous purge, but when they come through the pits and see and hear that there is also a 91mm in the car,... double
![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
