I have UMI tubular uppers and lowers. HR sway bar. Bilstein shocks. All new. On a light take off it makes a popping sound like somethings in a blind or getting alot of stress on it. I used the stock hardware on the control arms. Sounds like somethings going to break.
This is on the street. Whats it going to sound like at the track. I did use poly bushings in the rear end ears. Poly bushings on everything in the back for that matter. Normal driving is quite as a mouse. Maybe I should go back and retorque. Might have put too much on them? I could drill the frame and put 1/2 bolts in. UMI bushings are 1/2.
