nos gm
drturbo69
roof rail weaterstrips $300
door lower weatherstrips $250
outside dew belt moldings $150
inside dew belt moldings $150
trunk weatherstrip $100
87 gn black grill $300
grill emblem $50
gn black bezels $300
gn black markers $250
87 reman ecm-calpac-prom $250
hood lamp $40
power master switch $100
powermaster master cylinder overhaul kit $100
coil pack & gasket $100
heater control valve $50
r/s window switch no bezel $20
door striker pair $24
black iac valve $50
233 fuel regulator $40
injector oring kit $17
cruise lever switch delay $75
blue floor shift handle & 3 chrome rings $50
glove boxstriker lamp assy. $40
87 gray t horn cap assy. $100
lower intake $250
clear front park turn signal lamps $200
wastegate accuator $75
25519951 wheel fender trim $100
pull strap cover 4-correct gray $42
right front fender $200 no shipping
door skins pair $500 no shipping
t.p.sensor $45
dash bezel $200
carrillo rods new oncenter 6.35 wide $700
carrillo rods used oncenter 6.5 wide matched $450
bms crank std. std. 3.59 $900
used clear turn lamps one has crack in corner $45
DOC
Another PM. You have to be up a few more minutes earlier then Bob :eek::D
