Not Using All Cells?
HighMileage
Albany,NY
Which way are the Cells counted? If they are counted 0-14,left to right starting at the top,I don't seem to be using 4,8,9,12,13 and 14. They are each stuck on 128.
Also,in each of my logs,they never get highlighted yellow.
This is after about 500mi in all types of driving conditions since my last ECM reset.
Shouldn't those cells be showing something different by now?
Thanks,
Steve. '87 GN. Stock with stock chip and PowerLogger.
Here's a link to how the cells are numbered:
Just click on the picture to enlarge it.
If you're running a stock chip, yes, all the cells should be being used.
Cells 7 and 11 during cruise, cells 0 or 1 during idle, and cell 15 at WOT.
Thanks for the info,Dave.
Any idea why those cells I mentioned are not being used?
A chip issue??
I'm beginning to think that I should stop wasting my time with this stock chip,injector combo.
The only reason I can think of is that it's not really a stock chip.
You're right. I didn't read his original post close enough.
4,8,9,12,13,14 will hardly ever get touched.
You should make sure your have the latest version of the powerlogger, Bob has been adding a lot of features. That you will like..The yellow boxes should move as far as I know..
