Which Boostane are you guys refering too? 100 or 116. For street use of course.
https://boostane.com/
I use E85 now. It's wonderful. Short of doing that,I would use whichever of these 2 options is cheaper and I would turn the boost up to 20 lbs. if you can get the octane to 100.So no long time users of Boostane to chime in on their experience? I guess I'll continue to mix in 5 gallons of 104 unleaded because that's worked fine for the last year or so with no downside besides driving about 40 minutes round trip to fill up 2 5 gallon jugs & spending $110.
sounds great, besides testing the pump with alkycontrol test kit...Has anyone used a electronic type gauge tee'd from the nozzle with transducer into the car to watch pump pressure?where do u get it?
Since were in the topic of octane additive's, Is
Methyl Hydrate 99.9% (paint section)or Napa safety kleen meth parts cleaner 99.9% the same as M1 from vp?
Question-Methyl Hydrate 99.9% that u find at homedepot and methenol that u find from napa autoparts stores, Are all these safe to use & the same?Methenol is Methenol right doesn't matter where u buy it[/QUOTE
Yes, pure Methanol is the same no matter where you buy it. I still am not sure if Methyl Hydrate is even Methanol at all. Because if it was it would be called Methanol.
https://vpracingfuels.com/product/m1/
https://vpracingfuels.com/product-category/fuels/racing-fuels/
I take it that M3 & M5 are not suitable?
Same with me, I took somebody's advice & hollowed it out. I welded my testpipe right through the stock cat convertor so it looks stock if u look under the car.That's a classic. From what I understand from looking up boostane on youtube/internet it will turn the spark plugs & o2 sensors orange, weather it damages those parks not really said or known/ leaves a orange residue, Problably over time. And problably just better to just replace thoses parts now in then. But like somebody mentioned before does it leave any orange residue in the engine/ like on or around the pushrod's or piston not really known. I seen a test they made with torco& over time torco breaks up and small bits falls to the bottom like inside the engine. boostane seems to hold up/just change to a darker orange that problably ends up on the sparkplugs and o2 sensor.
Not counting/compared to the older octane addititives.. I'd like to know more about it if other people used it(boostane) because I only drive my car maybe 2000miles a year if that and it's less hassle than a meth kit from what I understand from the mataintence part of the alky injection, replacing the pump every couple of years/pressure test kit?They say it works, They say it's safe for unleaded pump gas/ classic car owner's etc. It was first designed for boat racing. It's not a sales pitch, I just like the price and less headaches. I'm not saying it's better than meth. Meth seems to be way better in more than one way.
These are all great octane boosters. I used all of them back in the day. Pouring this stuff in at the gas station drew attention and turned the heads of the other gas pumpers around me.Toluene,xylene,benzene,and naphthalene are all aromatic hydrocarbons. I use xylene because it has the highest octane of 117.
Yes, pure Methanol is the same no matter where you buy it. I'm still not sure if Methyl Hydrate is even Methanol at all. Because, if it was............ it would be called Methanol.
You could run a mix of AVgas (100 octane)..$6.00 here I think. I'd start with at least 80% Fill the rest up with 93/94.
U can run about 23# on straight 100 octane fyi.
Your 02 will last a little longer. You could run 20#. Keep a/f 11.3/4 low timing up top
I have used Boostane for the last two summers. I use their app and mix it to 95 octane. I have not had a problem running 19 pounds of boost with an old school stage 2 turbo on a stock engine. Just street use, never seen the track.
Aircraft fuel.Where's here my friend, do u live close to Toronto, Canada?
What's AV gas?
Please refer back to my post #51.From looking up in the internet Methyl Hydrate vs Methanol it's same thing just a different name. I found a VP racing fuel dealer with M1 ($30 5 gallons)not that far where I live.
Also give me some good info, I can mix 94 pumpgas with 110 octane to make 100 octane(20litres of 94+20litres VP110 to make 100octane. alittle pricely using 5 gallon cans $75bucks/ 110 is $110bucks a can. For me it's going to work out to be 225+tax a full tank on the street mixing with 94 pump gas, I think. not sure. He said I can fill up 110 at the race track and would be cheaper. But it's a 2 hour drive from here. No wonder everybody goes alky. Another store I found sells klotz 110 for $80(5 gallons)a snowmoblie race store.
Boostane sounds good but?the orange stuff it leaves on, problably looks like that in other places too, that maybe we can't see?The gtr forums make it sound alright. And read a mitsubishi forum said one used boostane alot and had to replace heads for some reason because of something else and inside the heads etc everything was fine, the orange residue came off with a cleaner.
