SignUp Now!But the flush breaks down some sludge.
U are correct on all newer vehicles
I used the stuff on an engine that had lots of sludge 40 years ago. It broke down the sludge and jammed my oil pump and broke it. I was lucky it didn't take out the engine.I would never ever use a flush because it will break stuff loose and get in oil pickup tube and turbo line and cause a engine failure , your best best is let it naturally flush with oil changes and hope for the best .New oil and filter is your best bet . Be patient it will clean up with time .
Motor flush all it is
Is kerosene. As long as u done rev the motor. While using it
u will be fine. Add to while its hot. Op temp .. run for 10 min.
Let it drain over night.
Really helps on a high mileage motor. On those cars that people Only changed it once a yr
Ive bought a ton of those
I need to do this asap. not to hack the thread, but which oil should you use? I ordered the oil additive from kirban. I have 5 quarts of quaker state what ever weight the motor states. and I also have mobil one. but was told I don't need mobil 1 if I use the reg oil with the additive.
any info would help..
