oil filter
garrett
Has anyone ever heard of a Buick V-6 engine imploding or sucking in an oil filter? I have an engine that did this to an oil filter. I changed the oil and put on new oil filter and it did it again, not as bad. I have since swapped out the motor, but I still would like to know what is causing it?
Are you talking about collapsing the filter media or collapsing the outer metal shell? :confused:
filter
I'm talking about the perforated inner structure. It sucks it into the center.
Do you have your filter bypass valve blocked??
I have had this happen to a Fram filter, but never AC Delco. I have my bypass plugged. The filter sees 100% of the oil flow with the bypass plugged.
You should never plug the bypass unless you have mods to handle the flow on cold startups.
yes
Yes, I do have the oil bypass blocked. I also run 20w-50 motor oil. Should I step down to a lesser viscosity motor oil? What associated mods are you talking about?
filter
that's just the short version of the same filter. The filter is not the issue here.
