Hi Guys & Gals-
A lot of food for thought in these posts. this is certainly a worthy topic. So, here's my two cents' worth...hopefully it's not more info than any of you wanted:
I am the third owner of my car. It has 80K.
POLL RESPONSE: The previous owner specified Mobil 1, 15W-50...so that is what I have been using.
I am giving some thought to what one of our esteemed senior members said about too wide a spread between the viscosity numbers possibly being of concern. I do not know anything about this, but may try to find more info.
FILTER: I am currently using the PF 52 filter. However, I may use the PF 47 next time because I think there is some merit to the belief that a smaller filter pressurizes faster than a larger one at start up.
OIL CHANGES: I change oil every 3K miles...with a new filter. With a turbo that spins at 100K RPM, I will not take a chance with longer change intervals.
LIFTER NOISE: I have only had lifter noise after the car sat for over a month, even after I primed it (ECM unplugged) there was some click that disappeared after about 30-45 seconds. I get no tappet sound if the car sits for up to two weeks and I prime it.
FACT OR FRICTION?: The following is out of a 2004 Mobil 1 brochure with a lot of FAQs about oil and should help answer some previous questions posted in this thread:
OEM USAGE: Mobil 1 is "original equipment" for the following cars: Corvette, Porsche, MB-AMG, Aston Martin, Mustang Cobra.
VISCOSITY: 'At very low temperatures, when the oil needs to be "thinner" to flow readily, Mobil 1 is capable of pumping easily while conventional oils can thicken substantially. At very high temperatures, when the oil needs to be thick enough to provide a film on engine parts...Mobil 1 resists being squeezed out of the contact area between metal surfaces by maintaining its viscosity.'
HIGH TEMP PERFORMANCE: Mobil 1 is "capable of protecting engines at temperatures up to 400 degs. F."
FLOW CHARACTERISTICS (Pumpability): 5W-30: -51 deg. F; 10W-30: -42 deg. F; 15W-50: -35 deg. F.
VISCOSITY FORMULAS: The 15W-50 is the "Performance Driving Formula," "excellent for supercharged and turbocharged engines, muscle cars, and amateur racers." It is M1's highest viscosity oil and is "race proven."
10W-30 is described as "Higher-Mileage Vehicle Formula." It is M1's best seller.
5W-30 is "Newer Vehicle Formula."
ADDITIVE PACKAGE: Some members use the GM EOS or Valvoline Syn Power Oil Additive for the Zinc and Phosphorous additives.
M1 says it includes anti-wear agents including SuperSyn - a proprietary anti-wear system that "has astounding protective properties. Instead of breaking down during extreme high-stress, high-temperature conditions, the SuperSyn actually excels..."
SuperSyn was originally developed in response to the engine protection needs of drag racers running supercharged nitro-methane engines. The first use of experimental M1 with the additive package allowed their engines to last longer. NASCAR also used the new formula and "it provided incredible performance."
Check this out: ExxonMobil does NOT recommend the use of oil supplements with Mobil 1. 'According to the American Petroleum Institute (API) and Alliance of Automobile Manufacturers (AAM), "certified oils eliminate the need for supplemental oil additives."'
Now, how much of this is science and how much is the protection of corporate interests is up for debate. I would like to know if there is any independent lab testing with contrary data. If any of you guys/gals believe supplements are necessary, please post the link to the scientific data so the rest of us can see the proof of a need for supplements (other than Vit C and B-complex...oops, wrong forum).
TURBO BENEFITS: M1 helps "prevent coking (oil literally turning to carbon) in an oil-cooled turbocharger" because it provides "high-temperature oxidation stability." Since turbo engines generate significantly higher temps, "especially in the area of the turbocharger bearings after engine shutdown...these elevated temperatures can cause coking of conventional motor oil."
ENGINE BREAK-IN: It is a "myth" that new engines need a break-in period using conventional motor oils. Summing up the info on this...in the past, engine break-in was necessary to remove metal flashing left inside the engine after machining.
"Today's engines are built with much tighter tolerances...much improved machining...under much cleaner conditions compared to engines of 10 or 20 (that's US) years ago. ...Mobil 1 has shown excellent results in industry standard ASTM tests" for rebuilt engines. "...these tests demonstrate that proper break-in using Mobil 1 is not a concern."
My feeling is that I would rather go with a conventional 30wt break-in and drive the first 1k miles on 30wt (easy on the turbo juice-no red line runs) before switching to a synthetic. Why? Cheaper and just a personal preference...as long as I did not punish the turbo. I guess if someone wanted to spend more money on synthetic as the break-in oil, and be able to spool up now and then knowing that the synthetic would protect the turbo, that would probably be okay too.
SEAL LEAKS: "Mobil 1 does not cause leaks. It is fully compatible elastomer materials from which all automotive seals and gaskets are made. If an older engine does not have oil leaks, Mobil 1 provides the same advantages as when used in a new engine." So, if you got a leak, fix it.
How did this idea of synthetic oil leaks get started? The Mobil brochure explains: 'Over 25 years ago, when Mobil 1 was first introduced during the energy crisis, it was a very low viscosity grade (5W-20) for optimizing fuel economy. At that time, engines were designed for much heavier grades of oil (e.g. 10W-40), and tolerances were much "looser" than in today's engines.
Ironically, the original formula in Mobil 1 in an older engine sometimes leaked out the sludge that was keeping oil from leaking. The result was that Mobil 1 literally leaked out of some engines.
...with engine designs produced since the mid-1970s, this phenomenon has totally disappeared.'
Whew! Hope that helps.
Steve
Steve
   lol
  lol
