Jerryl
Tall Unvaccinated Chinese Guy
- Dec 14, 2004
Yes you are correct. Smooth consistent drag.Squid4life said:....... But it has been said that you will feel the gears "mesh" with oil present, right? It doesn't feel like a catch at a certain point of the rotation, but like each time the gears mesh.
The oil pump did have a tiny leak when you revved the motor, around the thin crappy paper gasket. Maybe this is due to the convex cover, leaking a bit of oil, but also sucking air, in turn losing prime.
I am with you, Jerryl, on replacing the front cover and oil pump cover. I am getting scared that if it is not set up correctly or is convex/concave that the gears will grind the aluminum, which will end up in the bearings, and I will be back to square one.
Probably nothing to worry about and not trying to alarm you but ........ with possible air/oil mixture, do you think you could have gotten some air bubbles in the oil resulting in a "less than perfect lubrication" to the bearings? While you have the cover off, would it be worth checking "just one center" main bearing?
I am using this one (bottom of the page);Squid4life said:Where do you guys buy your front covers/oil pump covers???
http://www.taperformance.com/Timing.htm
Try here too, same unit, $139 complete!
http://secure.johnsperformance.com/...1770.21290*2Q3dj&next=20&product=Engine-Parts
