In this thread there are 2 different booster/thrust plates referenced. My plate at the beginning of this thread required that the relief valve recess on the oil filter half of the oil pump be extended so that oil could be passed thru the smaller of the 2 elongated holes in the plate. The problem I had was that 2 standard non-booster plate gaskets were used. Once I cut the small elongated hole out of both gaskets oil from the relief valve can now flow threw the smaller elongated hole to the channel in the timing cover half of the oil pump where it then gets fed to the back end of the gears. It doesn't matter that both gaskets have the gear opening in them. The gasket picture provided by Quick6'n'-KC Bryan is a different plate than mine. The top gasket in his picture is a standard gasket that would go on the timing cover side of the plate. Assuming the lower gasket in the picture matches all holes in the plate that came with it, the fatter elongated hole would align with the relief valve recess on the oil filter side of the oil pump and oil would flow thru it to the front side of the oil pump gears.
