oil pump shims
bluettype
who besides ta sells the shim gaskets for oil pump cover? they're closed to after the new year
i used 2 gaskets, but thats cuz i had an extra, if u don't have, then i guess you'll hafta wait.
If you cann't wait go pick up a mellings oil pump rebuild kit, there several in there, under $20.
If you have a GM cover I have been using .008 paper gasket. The HV kit comes with 2 gasket of different thickness. I don't use the HV gears just the gaskets. If you have an aftermarket cover the thinest one you can get,that would have to be from TA. The gears are recessed on all aftermarket covers that I have used. GM's are above the cover. Another VERY important area is the side clearence. .003 is where it should be. If the inside of the cover is all grooved up it maybe be better to get another cover. GM is about $200 if it's not discontinued.
