Success!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!
Well... after springing fuel leaks, too high of fuel pressure problem,
used coil pack and module from someone here on TB awhile ago that had the
coil pack installed backwards. Wiring snafu's ...............
IT's ALIVE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Once I got the coil pack on right it didn't even turn over one revolution and it
was running great.... Broke in the camshaft filled the coolant... no leaks
anywhere Hooked up the fans from Full throttle.. wow.. they pull some air!
She kept nice and cool.
Turbotimmrs old TE 63 was spinnin with no actuator hooked up..
Throttle responce with 40lbs fuel pressure seems great. I had to install
a new IAC.... but now it idles fine...
Lonnie's 2004R went through all the gears just fine.. .just about came off the
hoist when it shifted each gear :biggrin:
I'm estatic... Tomorrow more cleaning up of wires... final install alot of stuff
bleed brakes, install shifter cable and it could move around on it's own power!!
THanks a ton guys for all the support and help...
I'll have more questions for you when it comes to the actual tuneing but
that'll be after it's done at the interior shop...
Again, Thanks!!!!!!
Scott!!!!
