Originally posted by d0n_3d
where am i going to start first? i am gonna rip out the motor and tear it apart!!!
actually i still cannot figure out why my blms at idle are always pegged out at 160...i just cannot figure out why it runs so rich at idle...cruising around and WOT it's fine
once i get that figured out i think my car will run perfect...or close to it...
If your BLM are pegged, a few things could be the problem. the o2 sensor is controlling the INT in closed loop operation of the ECM.
The INT drives the BLM numbes toward a stoich a/f ratio. If the ecm is in closed loop the o2 sensor will control the INT that drives the BLM numbers up to correct for a "lean" measurement the ECM is reading.
BLMs are controlled by air flow numbers and RPM, thats why you're seeing a normal 128 WOT. It's got to be somewhere on the basic scale that is causing your problem. HTH, Jason
