Wow here is some info i found on a site
Quote
o these simple and low budget modifications and your 2nd generation T/A will be running mid 13's at the strip on pump gas.
My 403 parts list:
403 ci Olds stock bottom end
1968 #5 Olds 350 heads, drilled for 1/2 inch head bolts, milled .015, 3 angle valve job with full port and polish.
110/320 valve springs and stainless steel OEM size valves.
Edelbrock #3711 intake port matched to the heads.
Jet stage 1 Q-jet Carb
Pertronix performance HEI kit.
SSI 214/224@ 472/496 lift cam and performance lifters.
Dynagear double roller timing chain.
2 1/2 inch dual exhaust with Dynomax Ultra-flo mufflers
Richmond 3:42 ring and pinion with kit
B&M Shift kit
I did all work except the head milling and valve job. Total parts cost: $1,661.99:quote
Wow not bad, but all that and hes hoping to hit mid 13s
Nice set up for the street but not enough to even talk smack to the most lightly modded buicks. I'd love to know what your mods are? don't tell me its gonna have a holley 750 double pumper with mechanical secondaries and that will get you close to 500 hp with the stock manifolds?
