SignUp Now!I'm not clear on your terminology. Doesn't a booster plate turn your oil pump into a high volume pump? What are you referring to as the booster plate?both main a rod bearing clearance at .002 with 30lb oil pressure at hot idle! No high volume oil pump just a booster plate!
A Topic with lot`s of opinions. I personally prefer .002 - .0025 on ALL...
And I use 25/50 Penzoil...:smile:
You're using a dang good oil there, Joe.
Interesting thread, I've always heard tight, tight , tight. Good to see all the different responses....Chuck
