So it looks like Tom at Champion got it right with spring set up on my heads. While this is my first dealing with Tom, I 've heard good for so long about Champion I'm not surprised. 1.700" is a good height for my 206/206 roller, since it appears that most folks are far more concerned with achieving full compression at max lift than setting up for spring pressure. I spoke with Mike at Full Throttle. He says they set them up like this typically at 1.700 and get in the .060-.070" from bind neighborhood at full open. In addition, the PAC 1201 spring I've found out is in many cars here and friends cars with very similar set up with great results. The shop is going to reassemble and we're good to bolt 'em up and get measuring for push rods. If I was doing this over from scratch I may have looked for something with a little less rate than the 1201, not sure what.
I learned a great deal about the subject from this post and as usual, this great group of knowledgeable, helpful cats. Thanks to all for opinions, input and time!
