HelloBozos
A Bozo in Buick
- Feb 9, 2011
I, Under WOT had the factory rubber boost line slide off the factory metel boost line, I saw 26psi boost out of a gt-71 on stock block steel head gaskets. The XFI cut the motor but not quite soon enough through one my bad karma moments.(the XFI was at max boost)Before i had piston pin come out,I'm guessing on the dyno with it being new the reason for me sleeving number 4 cylinder.After the line came off,I'd loose all the radiador fluid in 20 minutes of drive time,the car still had all it's power an had no leaks anywhere. What i did was Cracked the sleve...8^(...going chrome molly or new block if it is damaged.I'll have to take my billet mains out this one into a new one if i have block damage
