SignUp Now!Update: Boost backed down to 20psi, WOT run (no knock), but fuel pressure and A/F still erratic. Fuel pressure input smoothing set to "off." Car feels great but still not seeing that smooth and steady fuel pressure or A/F numbers as the wideband attempts to kick in tracking mode. Screenshot below and full log attached. Also, see video on my fluttering fuel pressure at idle (has done this with multiple gauges).
The fluttering I see on that needle appear to be nothing more than that caused by engine vibration. There's very little movement actually. But look at the fuel pressure fluctuations on the graph display. I see more than 30# deviations!!! Your fuel pressure isn't flailing around that much. You've got grounding issues, hence my question about exactly where the fuel pressure sensor and WB are grounded!!
Have you tried a mechanical gauge taped to the windshield to see what it would do under boost? The bouncing needle on your video looks like it's from motor vibration. Could it possibly be electrical as the PL is reading a voltage?
What fuel pump? Hotwired? It would be nice if you could observe a gauge to see if it fluctuates. If the boost is actually fluctuating,you can expect the fuel pressure and WB to fluctuate.
How does the "all billet" regulator that a few vendors sell look inside? Do they have a better design for the seal?
Do you see the jagged line in the log for TPS. It should be straight at WOT. This also leads me to susspect an electrical problem. I would suspect the device teed into the TPS voltage first.
Accept for one frame,the WOT TPS voltage is either 4.66 volts or 4.64. That could just be an adjustment thing. If you rotate the TPS sensor just a touch or move it up or down in either direction,the WOT voltage might stay steady.I thought the same thing too but forgot to mention that! I think a good test would be to disconnect the TPS splice, reconnect the original connector, and go for a run. Although the fuel pressure trasnsducer would be taken out of the equation, if the TPS cleared up, then I'd be on to something. I could then run dedicated wiring to the input board for the Powerlogger (since it already has the ability to run a 5v sensor). Hell, might not be a bad idea to do regardless. I think I'll do that.
Also ordered a new wideband sensor from flea bay. Will see if A/F clears up also. Will report back...
I could be wrong, but your rail fuel gauge should be Liquid or Silicone Filled as the one in Full Throttle site
Your present fuel pressure rail gauge looks like a regular gauge, and no liquid filled.
http://www.fullthrottlespeed.com/customkititems.asp kc 001GMRAIL eq
Dave is right Bob says to never hook anything to powerlogger for 5v and gd cause it could cause pl and ecm to get wipped out if something goes crazy with that device .You might want to think twice about using the powerlogger's 5v source for powering a sensor. I'm not so sure it has enough capacity to do that. Better check with TurboBob before doing that.
The working temperature range for glycerin filled gauges is normally between 30 to 160 degrees. Silicone oil will withstand a wider temperature range (from -50 degrees to 300 degrees), but will also be more expensive.
Am I missing something here guys? By design, the input block is configured to run one 5v sensor if needed. It's right there in the manual. I have the transducer (a 5v sensor) hooked up exactly like is shown in the example given in the manual. Yes, there are warnings about ensuring that care is taken during installation and not to hook it up any other way...but nothing that specifically prohibits this.
this diagram is correct. you can run one sensor from the analog block.
what you never want to do is connect that +5v terminal to another source of 5v. Also, accidental grounding of that 5v terminal has been proven to kill the ECM and PL.
Note, that the current version of the PL no longer has 5v available at the analog block. (the instructions have been revised also)
Bob
Bob, what is your opinion of backfeeding the analog block's ground terminal? If I run an engine ground to that area, would there be any benefit to giving the PL and ECM a redundant ground path?
