Thanks for that input, Bob. I didn't realize there was a new version of the PL out. I'm confident in my install and don't see any instance where the wiring would get botched up.
For those of you following this thread, Eric is helping out over on his end as well. In summary, once the weather clears up, I will first test the readings and see if they've stabilized. I'm hoping that separating the TPS and the fuel transducer and giving them each their own circuit will eliminate some of the erratic readings. Once my new wideband sensor arrives, I will give that a shot as well. I'm suspecting a possible lazy sensor. In the meantime, I need to check the alky system again just to make sure it's output is up to standard...and then possibly the fuel pump.View attachment 213236
your signal wire is red? your 5v wire is green? thats a little non-standard, so I thought I'd ask....
B
