Jan 13, 2012 #1 9 9SECVSIX Member Joined May 25, 2001 Messages 520 Any suggestions on doing a black out on the white line bumper strip, the TR one was all I could find. FWIW it's a new piece. thanks B.
Jan 13, 2012 #2 D Danster Senior Member Joined Nov 26, 2001 Messages 1,346 I believe all are the same. To remove the white line, try using a lacquer or paint thinner to remove the white from the bumper strip. Maybe someone will respond on what they used that may have been better than what I mentioned above. Dannyo
Jan 13, 2012 #3 T turbojd Well-Known Member Joined Dec 27, 2005 Messages 1,983 Danster said: I believe all are the same. To remove the white line, try using a lacquer or paint thinner to remove the white from the bumper strip. Maybe someone will respond on what they used that may have been better than what I mentioned above. Dannyo Click to expand... X2, lacquer thinner works to remove the white strip.
Jan 13, 2012 #4 9 9SECVSIX Member Joined May 25, 2001 Messages 520 Thanks Guys. I'll give that a try.
Jan 16, 2012 #5 D dsa87gn Member Joined Sep 9, 2002 Messages 703 I used a power washer and it blasted right off
Jan 17, 2012 #6 M MSDGN Active Member Joined Jun 8, 2001 Messages 2,140 Denatured alcohol and some Q-tips...have done many that way...
Jan 17, 2012 #7 T turbonut85 Rarely used member Joined Apr 11, 2008 Messages 3,345 Laquer thinner here...worked great.
Jan 18, 2012 #8 Phoneguy Cometic HG stress tester Joined Aug 27, 2002 Messages 6,888 Someone posted on here before that compressed air will take it off. Bryan
Feb 19, 2012 #9 B Bruce Urie The Ventures,CCR forever! Joined Dec 30, 2006 Messages 3,254 turbonut85 said: Laquer thinner here...worked great. Click to expand... That was me......it's what I did and it worked just fine. I used the wrong quote......I meant that I used an air compressor to remove the white line...sorry. Bruce '87 Grand National
