Pair Champion proted irons, $775 plus shipping
Steve
I have a pair Champion irons I would like to sell. I bought these from a board member about 6 months ago and I took them to my engine builder to have them checked out and when he magged them both heads had a small crack in the valve spring area. I posted pics here on the board at the time and asked for advice and some experienced engine builders said that cracks in this area were fairly common and not a big deal and that they could be run as is as long as they pressure tested good. I went ahead and had the heads professional repaired just to be on the safe side and had them pressure tested. I also had the heads freshened up and they are ready to bolt on. They are set up for a roller cam. To sum it up they are a pair of CNC ported Champions irons with two small professional repairs. They are pressure tested and freshened and ready to go. $775 plus shipping. I will have pics soon of the heads before and after the reapirs.
Here are a couple of pics before the repair and and then after. The heads are fresh and ready to bolt on.
Ok sounds good. Let me know what you zip code is and I will get a shipping qoute. Thanks
