SignUp Now!last Minuit decision to go to track tonight. and I made it this time. it went well I still have some adjusting to do. the numbers are
pass 1 2 3
r/t .685 .738 .610
60' 2.182 2.302 19.53
330 5.468 5.597 5.168
1/8 8.170 8.307 7.858
mph 91.42 91.43 91.95
1000 10.475 10.615 10.155
1/4 12.428 12.558 12.093
mph 113.19 115.64 115.97
me and jdpolzin pulled my moter last night. It went ok, there was some issues. the big thing i wanted to post is the gunk on the injectors. not good. It seemed that I had to turn down the boost over time. I wanted to get a power logger to check the duty cycle. seemed to lean out. I guss it wes the gunk on injectors.
Ethanol melting the rubber fuel lines and depositing it where you are seeing it?
Ethanol does not melt rubber.
Goto: http://www.turbobuick.com/forums/e8...check-your-injectors-e85-injector-gunk-2.html
Go to post #36 click on that link and scroll to post #107.
The guy there had the deposits tested. The problem is definitely connected to the additives that are used in different parts of the country, additives that are NOT compatible with E-85; i.e. additives( detergents ) that would normally be used in pump gas.
It makes sense now why why people like me with a stock fuel system with over 25,000 miles are not seeing and it and other with brand new everything are seeing this issue.
E85 and rubber are a bad mix.
All new vehicles do not use any rubber in their systems.
Nylon, Teflon, Viton and various solvent compatible plastics are all commonplace now.
