pics of my BECool rad and RC dual fan setup
FlyinGN
all show no go
here are pics of one of my winter projects. Its a *beautiful* BeCool rad (#66062) for turbo regals. It is the ONLY alum rad out there that has BOTH engine and trans coolers built in.. Its a work of art.. and also how I installed a Ramchargers dual fan setup on it. I grafted the fans TO the rad instead of to the brackets like some others did. I did this because now the fan shroud is tight up against the the core so i won't need any sort of gasketing to keep the air from escaping from between the shroud and the core.. I found these studded fasteners called Rotalocs where you eboxy them onto any surface and now you have studs to mount things on to. I used the strongest epoxy that Loctite has .. Used for fastening the space shuttle's nose cone:). here are the pics.
Notice the size difference between the BeCool rad and the factory rad too. What do you all think?? Will I have cooling problems anymore??:) heh heh
Looks very impressive, how much was the rad alone?
Mark, you don't wanna know.. I got it for $525 but list is over $800 I believe.. Mine was new btw. I got a heck of a deal
Where did you get it for $525??? Gotta tell us the source if it a vendor,help your TR brother out:)
Dont see thta PN in Summit either. The one they sell for GN's is $1099 with fans:eek:
Thanks for the links:)
When you get it in the car let us know if it is a true "bolt in" radiator that requires nothing or one that requires a little tweaking. Thanks again:D
MAN THAT LOOKS GOOD! I wonder if the Mease INTTR1 would fit with that?
Thanks guys.
Broke1- I had the rad in already to line up the fans and marked where to place the tab/studs. The rad fit *perfect* dropped right in and the top rad plate bolted right up nice and easy.. :) Like it was made for it:)
As an ex Griffin aluminum radiator user. I have to ask this question:
Do you happen to know what the fpi (fins per inch) count is on this rad?
Dave, Im not 100% sure HOW to count the fine per inch but here is th eactual count. If you count each up and down I get 12 fins per ince. IF I count only the imaginary centerline between each fin I get 6 per inch.
12 sounds like a realistic figure. And with that you should be OK. Unfortunately, the Griffin I had (a prototype with both coolers), had a 18fpi count. This is pretty typical of the griffing nascar radiators, etc. Unfortunately it didn't proove to be very practical on a street car that seldom sees highway cruise speeds of much over 70-80mph. The fin count was much too high, and airflow through the radiator was significantly impared.
This however isn't much of a problem on a 200mph stockcar :rolleyes:
YOu should be just fine with the 12fpi
Beautiful job by the way!
" TOP DRAWER PARTS" , the icing on the cake would be a Brassworks BRA-1621 FLOW-Kooler water pump, summit stocks them but are not shown in hard copy catalog.
Again, "THUMBS UP" !
Blackhawk38
thanks. I have a top quality aluminum water punp with a flowcooler type impeller. Can't remember the manufacture tho.. I installed it 2 years ago. 800 miles ago
They are a really nice radiator. I bought a Be cool from a guy who never installed it for $550. I spent the time to polish mine before installing it. I went with the dual spal fans with it. It COOLS great.
Tarey D.
