mydesigner
BOOMER SOONER BABY!!!!!!!
- Dec 30, 2001
Do you have any pics of your interior it looks awesome from the little i can see of it.
SignUp Now!Originally posted by Donald McMullin
(1) Use B-spindle setup (like Bruce) which changes camber curve so tire leans in in bump creating more tire clearance. This setup has two downsides, (a) you have to make changes in tie rod connections to get bump steer corrected, (b) B-spindle pushes wheel hub out by about 1/2-inch so you need to change backspacing to have improve outside tire clearance and to minimize the scrub radius.
One caution regarding lowering the rear, do not lower the rear so much that the front mount for the rear arms is lower than the rear mount. This will not help the already pronounced problem of rear squat under load.
I have modified my rear instant center to add anti-squat and my 60-ft time have been reduced and my control using power has also improved (I do not use air bags). I have less power overstear coming out of a corner.
Originally posted by PRSRIZD_V6
What's wrong with heim joints? Their looks?
I've never used them on the street, but a tuthill 5/8" rod end is plenty strong enough for oval racing and I've never replaced one due to wear (sloppiness). I would also have to say they see much higher loads than would a street car. Not to mention years ago when OE tierods were used we replaced them about once a month, hence a rule change was made to heim-joints for safety and ultimately cost. Just MHO.
If you were using the pretty Aluminum ones that Global West (I think) was selling that is likely where your problems arose, get some good military spec ones.
Originally posted by AsphaltAnihil8r
Are you guys saying that I will encounter proiblems with steering when I do the change over next week for the 12" brakes...
I have Robert Adams Arms, B_body spindles ,1LE rotors,B-Body Calipers,,what an I going to run into as far as problems ,,what is bumpsteer,I'm confused![]()
Originally posted by bruce
While side loadings might be higher, that's just a fraction of what wears out a heim joint when used for rod ends.
Oval tracks are realitivly smooth, and hardly compare for the endurance needed for day in and day out use.
The oem tie rod construction has changed dramaticly, over the years.
Have a heim jointed car fail in an accident, and watch the lawyers eyes turn to dollar signs.
