Pictures of B& M Trans Cooler W Fan For Front Mount
DMAC
Here are some pictures of my trans cooler that is mounted under the front of the car. This is the best place I could find to mount on the car given I have alky kit running under battery , and didn't want to mount in front of my front mount intercooler with a heat source , I looked at mounting at the rear axle and rear tank area but didn't have enough suspension clearance that I felt wouldn't cause damage. I had the cooler run separate from the radiator.
It hangs right above the front air dams,
That will work
That’s a real nice option as long as you have a front mount. I have seen some mount it under the driver floor plan who have a SLIC. Looks pretty bada$$ that way. But you need a fan
