Well I had a great time!! On 255/60 drag radials Syd went 6.78 @ 103MPH at 21.5psi... I was thrilled to say the least . Track was in great shape... With a little better tire I think she has a 6.50 or better in her. I had a 1.54 60ft. She weighs 3760 with me in it so I need to shed a few pounds before THS in BG. I should be competitive to say the least in a few weeks so I am ready...
well........................
where do i start, I ran a best of 7.17@96 1.60 ft leaving @ 4psi on the T-brak. I think the boost was somewhere close to 35psi on pump gas and 22* of timing. Also stupid me left the laptop @ home. so i was driving old skool.
Is that knock i hear?
The car weighs 3795 with me in it
my stroker motor runs good...................................next up is a stage 2. if that don't run in the 6's. chevy Ls FTW
I bow to the mighty hot-airs.
My car's best run (Pat drove) was 7.063 @ 99.77 with only a 1.699 60'. Boost was 25-26 and timing was 24/20. I have upgraded to an XFI, Razors' alky control and a 6262 billet journal turbo within the last 30 days, so more tuning is required. I hope to be able to run 6.8s at 101+ on 93 + alky. Maybe then I can beat Eric's hot-air.
Some sarcasm with a hint of anger??? Did you hurt it?
K.
I'm not angry just a tad disapointed is all.
all this crap under the hood and it really is not any faster than my old .040 over motor.
lets see
.040 109 junk replacement cast pistons(heavy as hell) 200/200 flat tappet lunati cam bob stanley ported heads 1.65 roller rockers and a ported intake. the compression was just a tad over 8.1/1
it has ran a 7.21 @94.5 mph with a 1.65 60ft. shortly after that pass i hurt a head gasket due to the walbro pump giving up. on race gas
so now i have a
.020 109 diamond pistons stroker crank roller cam Ta alum heads with 1.65 rockers ported intake and a girdle. the compression is a full point higher.
it has ran a best of 7.17 @ 96 mph with a 1.60 60ft on pump gas @ 16 psi of boost with 22 degrees of timing.
so thats 5 psi different. so the bigger motor ran almost the same time @ 5 psi less boost.
but the bigger motor has more cubic inches (21 to be exact) and a full point higher in compression and it has a bigger roller cam.
that to me seems like it should be faster with less boost than the old motor.
I hope something changes my mind cause right now i'm regretting spending the money building this motor. All the other motor needed was head gaskets and a oil change
Pat,
Give your build some credit. Compliment your heads with a nice 70 series turbo. It WILL wake your car up. It's like taking a stock turbo and putting it on your old 040 motor. Great spool up BUT out of steam, on the top end, due to efficiency. Give me a call as I have a question about BG. Keep your head up hulio..
Darn Skippy! I'm the master of the 2 second 60':biggrin:
I've got a new rubberband on order and you guys just don't know what a big can of woop a$$ I'm bringing!
The motor is for sale you wanna buy it i'll make you a great deal........................
Are you really being serious??????
Hulio
Is that the norm or is that low for the buicks?
lets see
so now i have a
So, how are you Fast XFI boys feeling this morning?
