jimmymack87gn
Boost Junkie
- Dec 21, 2011
piston 0.010 out of the hole, will double stacking the stainless shim RJC head gaskets yield enough clearance??
SignUp Now!not asking about piston to valve clearance...Assemble the engine without gaskets and put some caly on the top of the piston. Roll it over by hand and see what happens. If the valve contact the piston you shouldn't be able to rotate it that far and you can pull the head to see how far the valve needs to go down.
Thanks!!!It will be close but should be ok. The piston rocking will be the
determining factor. I've run .010 out with a .040 gasket and had it clear. I ran .013 out and I
could start to see a light shadow on the head. Tight=power and efficiency
engine in my car has cometics & have leaked since day 1, building this one for a friendOrder Cometics in the thickness you need.
Don't know why i didn't think of this, am going to try it this week. I greatly appreciate all the input.Check the compressed thickness with a feeler gauge after install. I've found stacking gaskets doesn't add up like it should. Usually results in more thickness than anticipated.
