Ok, your car is wanting 21 % more fuel at its high point. You need to change #4 Base WOT Fuel - All Gears t0 150 as a start. Your current setting as is the preset 128. Yes its asking for alot more fuel so once we are close you might want to send the chip back to get the base setting closer so you can reset the computer and be closer to start. After looking at your log more i would bump the alky setting from 6 to 7 to help the injector duty cycle as well as the slight knock.
Put the timing back to 128 till we get the tune closer. no need to mess with the timing for now.
Your 2/3 shift is high for a stock cam IMOP the 1/2 looks good
Your WOT TPS is to high. You need to reset it to 4.20-4.60 don't exceed 4.80
Closed TPS is good.
Time to look into a better cooling system
Time to look into some bigger injectors, are you running just 91 and alky? Thats alot of boost for that IMOP, we can lower your duty cycle some by spraying more meth but you really want to look into or consider bigger injectors if you do anymore mods.
What the setting on your alky kit, since your getting some knock i would bump it to 7 to see if it takes care of the knock issue as well as gets the IDC down some
Also from my calculations your converter slip looks good.
hope this helps some
