Plastigauge main bearing clearance?
Slix
101
4
18
38
New bearings for the main caps with crank in block (heads still on block)
Gonna try and sneak the uppers into place and need to use some oil so they slide in...
If I use plastigauge on the cap side of the bearing (installed dry) just figure my plastigauge on showing half the clearance because the upper bearing will already have the oil film in there?
Any thoughts appreciated
earlbrown
runs with scissors
May 26, 2001
7,031
1,245
113
48
lagrange, GA
One of these days I'm going to use my bore gauge to see just how inaccurate plastigauge is.
Slix, what's going to be your procedure to know for 100% certain you don't put a small piece of crud up into the main saddle in the block (or even worse, into the oil feed hole)?
Slix
101
4
18
38
I was hoping to find something the shape of a mushroom and the stem would fit inside of the oil hole and into the actual bearing that would just be enough to hold the bearing so it sounds out when I rotate the crank..
I was thinking if I could do that then the bearing would actually wipe away anything that was in the saddle and when I put the new bearing in it should already have a clean surface...
Haven't really had any luck finding the mushroom pin thou
Plan B which is roll new bearing in after I push the old one out and then maybe put something through the oil hole like a Q-tip..
Wish there was some way I could pressurize the oil system and then just blow air through it and it should push anything out through that hole?
Guess that's something I think about thanks.. any thoughts appreciate it
bison
Moderator
Staff member
Dec 19, 2005
16,807
1,513
113
42
CT
It depends on the reason why you are changing the inserts. Plastigage is certainly better than using nothing. If you knew the bearing clearances you previously had a bearing mic would be more accurate in determining the oil clearance
Blown&Injected
3,117
6
38
Maryland
The one time I did that, the Plasti-gauge was right on with the mics and bore gauge.
  • Like
Reactions: No disintegrations
Top Bottom
