streetknight
DCVING
- May 26, 2001
Ok guys. I have a PLX SM-AFR wide band o2 setup to put on the regal tonight.
I am only hooking it to the Power Logger, no external AFR gauge at this time.
I want to make sure I've got the wiring right in my head before I start. This is how I understand it.
The o2 harness goes from the o2 to the sensor input on the SM-AFR (it has it's on plug so that's a no brainer)
The Power source from the SM-AFR. The module came with a plug that goes in the Module and has 1 red wire and 1 black wire. I put the plug into the SM-AFR, the red wire to 12v with key on, and black wire to ground.
The only other connection I need is from the SM-AFR to the Power Logger. The SM-AFR has an analog output that uses a plug that has 4 connections in it.
Top Left is 3.3V, Bottom Left is ground, Top Right is Narrow Band, and Bottom Right is Wide Band. It is my understanding that the only wire that I need to hook to this is the Bottom Right to the wide band. Then run that wire to the I/O #1 connector of the Power Logger.
Am I right or is their other connections that I need to make? Again, I'm only hooking the WBo2 to the PL and not an external AFR Gauge.
TIA
TIA
