jshot
 - Aug 8, 2018
so i took it to a local GN guru. got lots of advise. sounds like i need new headers and gave me some advice on my 2-3 and 3-4 late shift at WOT. anyhoo he says the pedal feels normal but might need some more bleeding. he also noticed a little fluid around the brake pressure switch. it was not dripping but it was wet just under the switch we cleaned it off and i will keep an eye on it, he said even the most minuscule leak could suck air.book say it should travel 2,25" with 100# applied ..what i had was with almost no pressure it would move that far and assume thats what you have going on as well...still havent tested the one i have that has been rebuilt ..have to bolt it up to a car to find out if oring kit fixed it
I am also getting use to the pedal. but would lie to reduce the 60-0 of 230. i will do some more bleeding.
